I have just purchased a 12/275 VE inverter to go in my small static caravan, which is powered by a 12v solar array and 120 ah Lithium battery. The AC outlet on the inverter will be connected to a 2 way extension lead block. I want to power a laptop charger and a DeWalt 18v 5ah battery charger (for my cordless tools). Is it enough for me to run a cable (6AWG or 10AWG) from the inverter earth connector to a copper rod that is inserted into the ground? Or should the AC outlet be run through an RCD first before being connected to the 2 way extension block? If its the RCD route where does the earth ground for the inverter go to? TIA.
Related topics
| Topic | Replies | Views | Activity | |
| Is my grounding safe? | 2 | 291 | 30 April 2025 | |
| Grounding... I need help | 3 | 196 | 8 September 2025 | |
| 3000w Inverter | 5 | 262 | 8 September 2026 | |
| Victron Phoenix Inverter AC Ground/Earth? | 2 | 662 | 7 June 2025 | |
| Pheonix 1200/12 Inverter earthing (floating neutral) | 10 | 855 | 21 June 2025 |
