I need to replace a failed ProTronics battery charger with a Victron battery charger which will integrate with my Bluetooth Victron solar MPPT. For ease of installation I would like to hard wire the existing 120V input wires into the charger. The charger is 12Volt, 3 output, 30 amps. I am only finding Victron chargers with a cord and plug as in the Phoenix Smart IP43 and Blue Smart IP22.. The Skylla series is hard wired but is 70amps and is to large for my application.
Does Victron sell a smart battery charger rated 12V, 30amp with a hard wired 120V input?
The Smart IP43 Chargers use an IEC 60320 C14 inlet, its counterpart is the IEC 60320 C13 plug, which can be bought as just the plug without a cord, so you could reuse the existing wiring. For example:
https://www2.mouser.com/ProductDetail/Schurter/4782.0100?qs=h0lr9otJFD5HNkLVcCkIJA%3D%3D
I guess that comes closest to a hard wired input apart from the ones you already found
Thank you so much for this answer. Great idea which I will do.
