[3.60-11] Inverter use grid even if minimum SOC is not reached
See a strange behavior. My min soc is set to 50%. No DESS. Inverters (3xMultiRS) are keeping 75% and don’t go down. What can be the problem?
Ok, 5 mins later it starts going from battery. That’s makes it even more strange
Optimized with BatteryLife is set?
Set “optimized without battery life”
Try without BatteryLife and see if it’s dropping to 50%.
Remember, BatteryLife increase that minimum SOC with 5% for each day without enough sun…
LE: Sorry, now I’ve seen that you’ve said it’s without batterylife… sorry… :blush:
