2x Multiplus II 10KW in parallel single phase external transfer switch
Can I combine the master OUT-1, the Slave OUT-1 and the GRID on the Same busbar? My grid service is 60A 230V single phase. as recommended by victron for on three phase system for large inverter, I’m installing an external Contactor.
Are you trying to connect AC IN and AC OUT on the same busbar?
No only AC OUT 1 of both 10KW inverters plus the incoming grid.
Did you notice that the grid and the output of the inverters has a contactor between them?
Yes, thank you for the update
