24Volt system entegration to 48Volt Cerbo System
I am managing and monitoring a system with 3 Quattro 48/10,000 inverters, 1 MPPT RS 450/200, and lithium batteries using Cerbo GX.
Now, we are integrating a 24V battery bank, which will be charged via an MPPT connected to solar panels. This 24V system will only supply DC loads.
We would like to connect the 24V battery bank and solar system to Cerbo GX solely for monitoring purposes.
Will the devices connected to the 24V system have any impact on the operation of the 48V system?
Why not just add another GX or Pi for that purpose?
You can technically add another system via a mk3 adapter, this is in the manual but you lose any intelligence which you would get with a dedicated GX.
I would just install a SmartShunt to the 24V System and connect that to the Cerbo.
You just need to be careful to select the correct battery monitor for the 48V system.
