16S ncm battery and ESS issue
Hi guys, I made a 16S NCM battery with 12 modules of a Renault Zoe (54kW) and when I create a new type of battery in the VE configure 3 and activate the assistant ESS and I choose to mantain this type of battery when I upload the settings the multiplus II give me low battery warning, any help? ( if I go for the recomended battery LiFePo4) the system works …
I get the error 6 in the VE bus… I have all with the same settings or not…
Please add your VE.config file or make some screenshots of the settings (inverter tab and dynamic cutt-off in ESS assistant).
The NCM cell is about 3.7V per cell.
A 16S battery is a 59.2V battery… Isn’t it a bit too much?
Or, if you, as you’ve said, have 12 modules, so 12S, that will mean 44.4V… Isn’t it a bit too less?
What’s your battery open circuit voltage?
