I have a Centaur 12V 60Amp AC DC Charger that is showing an output of 20V when charging at the batteries and has cooked all 6 batteries. Could this be a failed charger/regulator (is it internal?) or could it be a few bad batteries that started the problem?
My theory was if a few batteries went dead then the charger may try to overcompensate and send a higher voltage?
Thanks for the help!
