I want to control the Growatt inverter like MIN 4200TL-XE. There is a Shine WiLan-X2 dongle available that supports modbus TCP. It means a set of registers can be accessible. I would like to work with a virtual PV node for a PV inverter to limit the output power (zero export). Who has experienced with this hardware configuration?
Related topics
| Topic | Replies | Views | Activity | |
| AC PV Inverter power limiting via virtual device, possible? | 19 | 708 | 16 September 2026 | |
| Growatt MQTT to SunSpec Modbus TCP Bridge for Multiple Inverters | 6 | 403 | 4 August 2026 | |
| PV inverter control via Node-RED | 1 | 580 | 17 January 2026 | |
| Adding RS485 USB stick to communicate with PV inverter via Nodered | 1 | 130 | 21 June 2025 | |
| V3.71~2 PV Inverter control node missing measures | 0 | 69 | 12 March 2026 |
