When using NodeRed I cannot select a measure in my PV Control Node anymore? I can select my inverter but in the measures drop down it only shows power limit (W). This was working fine in the past and my current flow is still working I just can’t change anything anymore since the choices are missing.
Related topics
| Topic | Replies | Views | Activity | |
| PV inverter control via Node-RED | 1 | 575 | 17 January 2026 | |
| Howto create a new PV-inverter Dbus (+VRM) instance with Node-Red | 11 | 2123 | 3 August 2025 | |
| Node RED MQTT OUT PV Inverter in Venus OS | 5 | 490 | 15 April 2025 | |
| Virtual PV Device example? | 4 | 398 | 15 March 2026 | |
| Feature Request: Dynamic Power Limitation for Nodered Virtual PV node with DESS | 1 | 125 | 1 May 2026 |
