Wrongly configured both my Orion Smart and my SBP
Hey everyone!
I wired and configured both my Orion Smart Non isolated DC/DC 12/12 - 30 and my SBP 65A today and I think I did it wrong.
SBP : I wired everything (IN, GRND, OUT) and then went to Victron Connect to finish its configuration. I started doubting when despite disabling the “Load Output” option, my 12v circuit is still up and running when (from what my understanding) it should be isolated from the battery. Victron states that the OUT should be wired only after the configuration process, do you think that the way I configured it could be the cause of my aforementioned issue?
Orion Smart : Pretty much the same thing, I wired (IN, GND, OUT) and configured it via Victron Connect and went for a test drive. Again, Victron States to configure it first with the car battery and then plug the auxiliary battery once done. What made me doubt is that my Orion Smart was indication a “Float” charging state when it should be in “Bulk” because my LiFePO4 Battery has a SOC of around 25%. Could this be related to my configuration?
TL;DR : configured wrong both my Orion Smart and SBP by wiring and running everything and then going through the Victron Connect procress and now I seem to have issues.
Thanks!
