VRM is showing wrong grid values. When running through the night there is no feed to the grid as there is no solar. I can’t solve why this would be
Do you have a 0w setting on grid?
Sometimes in systems there is a bit of back shoot when loads turn off (this is normal even in nom inverter systems), you just become aware of it when there is monitoring.
Load up a voltage amps graph in the advanced section and see there.
Thank you. The system draws 50w from the grid when using the battery. Voltage/amp chart from the grid meter?
Yes. Does it always show the positive draw of 50W
Ah right, you have a three phase system so phase compensation comes into play.
And FAQ 14
Do you have loads between the inverter and meter?
Firstly, I very much appreciate you taking the time to point me in the direction to learn and solve this issue. I will read through the FAQ to understand the issue/limitations. I have attached an outline of our system. It was designed and installed by a local company — monitoring is done through their proprietary app. VRM offers much more granularity and flexibility if I can get it to report accurately.
