Wrong (I guess) AC consumption
Hi!
I have a 24v Motorhome equipped with:
  • 8K Quattro
  • Cerbo GX (position of AC loads set to: AC input & output)
  • Victron lithium smart batteries paired with a BMS v2
  • Batteries connected via a Victron Smartshunt (correctly set as battery monitor)
  • No external energy meters
  • All 24v DC
What I’m constantly seeing is the following situation - considering that:
  • I consider for right the smart shunt readings
  • DC power is calculated
  • AC loads is constantly exaggerated
Just to make it clear I don’t have any DC source of energy but only loads.
Could it be that I have a faulty smart shunt?
Thanks
How is your system wired? It would help to post the schematic too.
When you say AC loads exaggerated - by how much? AC Loading will be measured by the Quatro, but low level loads are likely to be less accurately measured.
If the Battery BMS is talking to the GX device, then you should not need the shunt as a battery monitor.
I will grab a picture of the schematics provided by the producer of the motorhome - it’s a big install (for a motorhome!). When I say exaggerated you can refer to the screenshot I attached earlier: I’m consuming 353w from batteries, but the quattro see 515w of AC loads so it guess DC is generating (while it’s a load) 198w..
I don’t know exactly how much is really my DC load but would guess 100w? so AC readings is wrong by 250w…
Is your DC load 24V or 12V?
sorry should have mentioned: 24v
working on the peak ac power of 8kW, that’s ~3% error. so not so much. Problem with digital measurements is that people expect them to be 100% accurate, where as in reality, there is always an analogue stage to these measurements, and an A/D converter buried in there. These lead to errors, especially at low levels.
I don’t think you can use BMS v2 as battery monitor:
Mike I have 250W of error on a 500w load - it’s 50%
ok with the battery monitor.
Error is measured as % of full capacity of the inverter. Even with no physical load, a Quatro will give some indication of load current due to circulation currents - usually capacitative in nature for light or no load.
understood and agreed but this is leading to DC loads being considered source of power rather than loads!
regrettably, this always happens.
It would be nice to have higher resolution AC measurements in both Quatro’s and Multi’s, but that would inevitably lead to higher costs.
Power measurement is particularly prone to error as it is the product of two or 3 other measurements, each with their own inaccuracies. The 3rd measurement is phase angle (between voltage and current) if V and I are measures as rms, or just two if instantaneous values are used, and rms power subsequently calculated.
ok Mike so adding an energy meter in your view would entirely solve my issue?
I Think it would if you need that level of accuracy. This is not something that I have done. I just accept the small errors at low power.
Here is the schematics of the system
