From my understanding of the MultiPlus 2000VA there is a single AC output. Does Victron make a model with more than one AC output?
Thanks!
Thanks!
What do you mean by the term “only one AC output”
The larger multis all have “2 outputs”
But they basically do the same thing … so there are 2 outputs … with ‘almost’ the same function …
I guess I mean two AC circuits. I want to run one circuit for one cabin and a second circuit for another cabin. Both circuits being isolated from each other. Is that possible with a MultiPlus 2000VA?
No … technically it is always just 1 inverter …
You could use a Multi and a Phonix.
What would the overall system structure be …
As stated in previous reply: the larger Multis have 2x AC Out, but they’re both being served by the same inverter - it’s just an extra output relay.
If you want two independent (isolated from each other) AC outputs, coming from separate inverters, you must install a second Multiplus.
Personally I see no reason why a single inverter should provide two separate AC Out circuits if separation by AC relays isn’t enough.
Wonder if the OP requires 2 outlets with 2 circuit breakers?
