I know this has likely been asked before, but my search didn’t provide any conclusive answers. Is it possible to wire the EVCS to traditional US 2 leg 240v ? If so what is the wiring config as I’ve tried all the obvious ways (e.g. - L1 Black, N Red, PE Green). Thanks in advance.
Answering my own question here - It does work with the aforementioned wiring moving L2 to the N with White (N) left unwired. My problem is that the EVCS doesn’t like the Neutral grounding provided by the Inverter and works fine when connected to Shore power.
