Who decides that a topic is solved?
I asked the question and did not get satisfying answer but topic was marked as “solved” and closed.
Why?
You have the possibility to “Unsolve it”, but only if the topic is not closed…
Just click on the “Solution” button of the message that is marked as solved.
From the same topic you are referring, below are some quotes…
I personally am using Firefox 115.19 and works.
Also using Chrome 104 and works.
1
Boy… Oh, my…
They didn’t have the same patience with me… :smile:
I mean, up until I’ve got some kicks on the buttocks from the moderators.
Probably it’s the new year beginnings and they have the batteries charged… :smile:
Please keep on topic.
The question of who can accept a solution is simple.
The OP or any member of staff and moderators.
One of the mod team (not me) accepted it.
The answer is correct and has been marked as such for the broader community, even though the OP may be dissatisfied.
Any repeats of questions already answered will be removed and anything that is not constructive will be closed. There has been enough disruption for something that can no longer be resolved here and for which the OP will not be satisfied. We do not like taking these actions but will if required. Thank you.
I marked the question as solved, because the correct answer was given.
Topic closed as advised above.
Last warning.
