Which Takes Priority—Battery Monitoring or Low Voltage Cutoff in VE Configuration?
Hi everyone,
I’m configuring my system and have a question about how different settings interact. If I enable battery monitoring in VE Configuration, and also set a low voltage cutoff, which function takes priority if both thresholds are met?
Will the system prioritize the low voltage cutoff to protect the batteries, or will the battery monitoring settings override this and allow the batteries to discharge further?
