Hi, am fitting a Victron Energy Orion-Tr Smart 12/12V 18A DC to DC charger to my Peugeot van in order to charge a 100ah LiFePO4 leisure battery. I will use 16mm2 wiring to connect them up, along with 60 amp fusing on both ends. My question is what connectors are best for joining the 16mm2 wire to the DC to DC charger? It doesn’t seem sensible to just twist the exposed wire and screw them into the charger. Are there some kind of crimp endings which people are using? Thanks!!
Have a read of this topic
https://community.victronenergy.com/t/using-ferules-pros-and-cons/1301/3
If you do, use bootlace ferrules and make sure you have the correct shape crimper and torque the clamps up properly and monitor to make sure they run cool.
Thank you pwfarnell, that link was really helpful ![]()
