What is digital input - touch input control - in Cerbo GX
can anybody tell me, what is a digital input from type “touch input control”?
I can configure this setting in my Cerbo GX, but no further setting or anything else is available for usage. Also the is nothing in the documentation as explanation.
It seems that the digital input type “touch input control” has replaced the previous type “Generic input”. I can find different information in the documentation on Node Red.
Unfortunatelly the digital input type “touch input control” is not available in Node Red, Changing the type from “Touch input control” to “Generator”, the digital input is usable in Node Red and also present in device overview on Remote Console.
Generally I am trying to use an digital input as pushbutton to control my dimmable LEDs which are connected to PWM on an Cerbo I/O Extender. The LED should dimm by 20% per push on a physical button.
Thanks Christian
With touch input control you can make a cerbo touch screen disabled for touch fuctionality
Ok, thanks… Does anymone know, how to re-activate the funcionallity of “generic input”?
From the manual: Deactivating touch input control using an external USB keyboard 1. Connect an external USB keyboard to one of the USB ports on the Cerbo GX 2. Press the Pause/Break key to toggle touch input control on/off. For keyboards without Pause/Break key use one of the substitute key combinations mentioned
