In VRM, click the top left menu, keep selecting “back” until you see the base menu with the “preferences” option.
Click that, choose “integrations”, then “access tokens”.
You can add a token from there, remember to write it down as you can’t access it later again.
Add a new config in the node and paste the token value into the relevant field.
Then deploy.
