Watt values way different between Multiplus and Battery BMS
Hi all,
I have a question about the values that my battery BMS and the Multiplus are showing. The amps and voltage are almost identical however the wattage is way off.
In above screenshot we see that the voltage is 53.71/0 and the amps are 56.0/55.8. As long as I can remember wattage is calculated by voltage X Amps which means 53,7 * 55,8 = 2996,46 watt. The BMS of the battery is almost right however the Multiplus is about 10% off…..
Any idea where this difference is coming from?
Answered on here several times, the W value in the Multiplus box is the ac power W, not the DC power W. 3355W ac into the Multiplus converts at 90% efficiency to 3000W DC. It is confusing.
