As above my Vrm is stuck on the new ui is there a way to switch back (yes I’ve tried via menus)
I believe that works when I’m on the local network but this is specific to when I’m using the Vrm app or Victron connect remotely
I did yes but only once
@Muzza
If you go the the installation
Settings - general (scroll down) you cen set or unset it there.
Brillo it works perfectly thanks very much
