VRM unable to access ESS controls
I have been recently upgrading my system, activating ESS about at the same time VRM has been showing some problem.
Today, it sems almost back to normal.
I have a small display problem when I use VRM and I select “ESS”. The information is not correctly displayed. Part of the info is cut on the right of the display. see screen capture below
I have tried with different browser, but I get the same result.
Can you do something to correct this or let me know where I can report this bug.
Thanks for your help,
JMV
That screen is swipe-able to the right :slight_smile:
Otherwise the different controls would’ve been too crammed / risky to misclick!
OK.
Thanks :slightly_smiling_face:
JMV
