Yes the widget is coupled to my installation.
I use NO bidirectional VRM connection (only for updates and multiplus setup.)
It worked until the day before yesterday.
I’m experiencing the same issue on my one device (but not on my other one). I’m also seeing that the status widget lock screen widgets have completely disappeared.
Noting that this has happened to me before. I did report it back when it happened the first time back on the old community site, but I never received any response on that post, and the widgets eventually started working again.
guystewart
(Guy Stewart (Victron Community Manager))
6
Hi Both,
I have seen this before, and as you have now both seen part of the problem is that it is so far not possible to replicate, even with identical hardware, and then often resolving without explanation.
Truely a frustrating bug.
If anyone else has the issue, please report it with as much detail as you can.
details I have:
Smartphone:
iphone 12 pro
iOS 18.1
(I never checked if I had this issue on 5G )
VictronConnect v6.09.1 (I can send you the service record if needed)
My network:
FRITZ!Box 6591 Cable (lgi)
Externaly connected via IPV6
internaly routed via IPV4
Nameserver via Pi-hole
VenusOS 3.5 on a RasPi4 Model B rev. 1.2
connected via lan: Ethernet port → 5port switch → 24 port switch → fritzbox → cable
