VRM recieving zero values from virtual device type energy meter
My VRM page is recieving zero values from my virtual device, at start-up or nede-red deploy.
I tried to catch all zero values in my function and in the debug window i do not see these zeros.
In moste cases these zeros are harmless, but especially for calculating the correct consumption it is quite anoying. Becaus this leads to unrealistic spikes in the VRM view.
My Flow:
        "id": "856ecdc694e20334",
        "type": "victron-virtual",
        "z": "bc27b6ec94076234",
        "g": "22e55e0c6aec1e5f",
        "name": "Ladestation",
        "outputs": 1,
        "device": "energymeter",
        "default_values": false,
        "acload_nrofphases": 1,
        "enable_s2support": false,
        "battery_capacity": 25,
        "include_battery_temperature": false,
        "battery_voltage_preset": "24",
        "battery_voltage_custom": 24,
        "generator_type": "ac",
        "generator_nrofphases": 1,
        "include_engine_hours": false,
        "include_starter_voltage": false,
        "include_history_energy": false,
        "grid_nrofphases": 1,
        "energymeter_nrofphases": 1,
        "energymeter_role": "evcharger",
        "include_motor_temp": false,
        "include_controller_temp": false,
        "include_coolant_temp": false,
        "include_motor_rpm": true,
        "include_motor_direction": true,
        "position": 0,
        "pvinverter_nrofphases": 1,
        "switch_1_type": 1,
        "switch_1_min": 0,
        "switch_1_max": "",
        "switch_1_initial": 0,
        "switch_1_label": "",
        "switch_1_unit": "",
        "switch_1_step": 1,
        "switch_1_customname": "",
        "switch_1_group": "",
        "switch_1_include_measurement": false,
        "switch_1_rgb_color_wheel": false,
        "switch_1_cct_wheel": false,
        "switch_1_rgb_white_dimmer": false,
        "fluid_type": 0,
        "include_tank_battery": false,
        "include_tank_temperature": false,
        "tank_battery_voltage": 3.3,
        "tank_capacity": 0.2,
        "ev_vin": "",
        "ev_battery_capacity": "",
        "temperature_type": 2,
        "include_humidity": false,
        "include_pressure": false,
        "include_temp_battery": false,
        "temp_battery_voltage": 3.3,
        "start_disconnected": true,
        "x": 550,
        "y": 80,
        "wires": [
                "c627e81c7b83067d"
        "id": "722014b859612718",
        "type": "function",
        "name": "Parse Modbus Massage",
        "func": "//initialisierung Speichervariablen\n// var time = new Date();\n// var thisTime = time.getTime();\n// context.LastTime = context.LastTime || thisTime;\n// context.Power = context.Power || 0;\n// context.Voltage = context.Voltage || 230.1;\n// context.LadeStatus = context.LadeStatus || 0;\n// context.vCarger1TotEnergy = context.vCarger1TotEnergy || 0;\n// context.vCarger1SessionStartEnergy = context.vCarger1SessionStartEnergy || 0;\n// context.vCarger1SessionStartTime = context.vCarger1SessionStartTime || 0;\n\nvar ChargingPpower = 0;\nvar data = msg.payload;\nif ((data[53] * 65536) + data[52] ==0) {return;} \n\nif (msg.payload.length >=70){\n    AcL1Power = ((data[19] * 65536) + data[18])/10;\n    AcL2Power = ((data[21] * 65536) + data[20])/10;\n    AcL3Power = ((data[32] * 65536) + data[22])/10;\n    AcL1PowerFactor = (data[46] >= 32768) ? (data[46]-65536)/1000 : data[46]/1000;\n    AcL2PowerFactor = (data[47] >= 32768) ? (data[47]-65536)/1000 : data[47]/1000;\n    AcL3PowerFactor = (data[48] >= 32768) ? (data[48]-65536)/1000 : data[48]/1000;\n    AcPowerFactor = (data[49] >= 32768) ? (data[49]-65536)/1000 : data[49]/1000;\n    // AcFrequency = (data[51] >= 32768) ? (data[51]-65536)/1000 : data[51]/10;\n\n    // power = AcL1Power-((AcL2Power+AcL3Power)/2);\n    if (msg.modbusRequest.name == 'Modbus EM-Whng1'){\n        if (AcL1Power > 3400 && context.Power ==0) {\n            context.Power = 3600;\n            context.vCarger1SessionStartTime = thisTime;\n            context.vCarger1SessionStartEnergy = ((data[65] * 65536) + data[64])/10;\n        }else if (AcL1Power < 2400) {context.Power = 0;\n        }else if (context.Power == 3600 && (2300 < AcL1Power && AcL1Power < 3200 )) {context.Power = 2600;}\n        ChargingPpower = context.Power < AcL1Power ? context.Power : AcL1Power;\n        // if (thisTime > context.LastTime) {\n        //     //var TotEnergy = context.vCarger1TotEnergy ;\n        //     context.vCarger1TotEnergy += (ChargingPpower * (thisTime-context.LastTime)/1000/60/60/1000);\n        //     context.vCarger1SessionEnergy += (ChargingPpower * (thisTime-context.LastTime)/1000/60/60/1000);\n        //     context.LastTime = thisTime;\n        // }\n        var msgCharger = { payload: msg.payload };\n        msgCharger.topic = \"Ladestation\";\n        if (!context.connectedCharger ) {\n            msgCharger.connected = true;\n            context.connectedCharger = true;\n        }\n        msgCharger.payload = {\"/Ac/Power\": ChargingPpower, \n                    \"/Ac/L1/Power\": ChargingPpower,\n                    \"/Ac/L1/Voltage\": ((data[1] * 65536) + data[0])/10,\n                    // \"/Ac/L1/Current\": context.Power/((data[1] * 65536) + data[0])/10, \n                    // \"/Ac/Energy/Forward\": context.vCarger1TotEnergy,\n                    // \"/Ac/Energy/Reverse\": 0,\n                    // \"/Ac/L1/Energy/Forward\": context.vCarger1TotEnergy,\n                    // \"/Ac/L1/Energy/Reverse\": 0,\n                    \"/Ac/L1/PowerFactor\": AcL1PowerFactor,\n                    // \"/Session/Time\": (thisTime - context.vCarger1SessionStartTime)/1000, //<-- Session charging time (seconds)\n                    // \"/Session/Energy\": ((data[65] * 65536) + data[64])/10 - context.vCarger1SessionStartEnergy, //<-- Session charging energy (kWh)\n                    // \"/Session/Cost\": (((data[65] * 65536) + data[64])/10 - context.vCarger1SessionStartEnergy) * 0.4, //<-- Session cost (no currency)\"\n                    \"/DeviceType\": 71,\n                    \"/Position\": 1, //       <-- 0=AC Output, 1=AC Input\n                    // \"/PositionIsAdjustable\": 1,\n                    \"/IsGenericEnergyMeter\": 1,\n                    \"/ErrorCode\": 0};\n    }\n\n    msg.payload = {\"/Ac/Power\": ((data[41] * 65536) + data[40])/10 - ChargingPpower, \n                \"/Ac/L1/Power\": ((data[19] * 65536) + data[18])/10 - ChargingPpower,\n                \"/Ac/L2/Power\": ((data[21] * 65536) + data[20])/10,\n                \"/Ac/L3/Power\": ((data[23] * 65536) + data[22])/10,\n                \"/Ac/L1/Voltage\": ((data[1] * 65536) + data[0])/10,\n                \"/Ac/L2/Voltage\": ((data[3] * 65536) + data[2])/10,\n                \"/Ac/L3/Voltage\": ((data[5] * 65536) + data[4])/10,\n                \"/Ac/L1/Current\": ((data[13] * 65536) + data[12])/1000, \n                \"/Ac/L2/Current\": ((data[15] * 65536) + data[14])/1000, \n                \"/Ac/L3/Current\": ((data[17] * 65536) + data[16])/1000, \n                \"/Ac/Energy/Forward\": ((data[53] * 65536) + data[52])/10,\n                // \"/Ac/Energy/Reverse\": ((data[79] * 65536) + data[78])/10,\n                \"/Ac/L1/Energy/Forward\": ((data[65] * 65536) + data[64])/10,\n                \"/Ac/L2/Energy/Forward\": ((data[67] * 65536) + data[66])/10,\n                \"/Ac/L3/Energy/Forward\": ((data[69] * 65536) + data[68])/10,\n                \"/Ac/L1/PowerFactor\": AcL1PowerFactor,\n                \"/Ac/L2/PowerFactor\": AcL3PowerFactor,\n                \"/Ac/L3/PowerFactor\": AcL3PowerFactor,\n                \"/Ac/PowerFactor\": AcPowerFactor,\n                // \"/Ac/Frequency\": AcFrequency,\n                \"/DeviceType\": 71,\n                \"/Position\": 1, //       <-- 0=AC Output, 1=AC Input\n                \"/IsGenericEnergyMeter\": 1,\n                // \"/ProductName\":,\n                // \"/CustomName\":,\n                // \"/Mgmt/Connection\":,\n                // \"/Mgmt/ProcessName\":,\n                // \"/Mgmt/ProcessVersion\":,\n                \"/Connected\": true,\n                // \"/DeviceInstance\":,\n                // \"/ProductId\":,\n                // \"/Serial\":,\n                // \"/HardwareVersion\":,\n                // \"/FirmwareVersion\":,\n                \"/ErrorCode\": 0};\n\n\n\n    if (msg.modbusRequest.name == 'Modbus EM-Whng1') {\n        msg.topic = \"EM Whng1\";\n        if (!context.connectedWhng1 ) {\n            msg.connected = true;\n            context.connectedWhng1 = true;\n        }\n                    \n                   \n                    \n        return [msgCharger, msg, null];\n    }else if (msg.modbusRequest.name == 'Modbus EM-Whng2') {\n\n        msg.topic = \"EM Whng2\";\n        if (!context.connectedWhng2 ) {\n            msg.connected = true;\n            context.connectedWhng2 = true;\n        }\n        return [null, null, msg];\n        \n    }\n}\n\nreturn;\n",
        "outputs": 3,
        "timeout": 0,
        "noerr": 0,
        "initialize": "// Der Code hier wird ausgeführt,\n// wenn der Node gestartet wird\nvar time = new Date();\nvar thisTime = time.getTime();\ncontext.LastTime = context.LastTime || thisTime;\ncontext.Power = context.Power || 0;\ncontext.Voltage = context.Voltage || 230.1;\ncontext.LadeStatus = context.LadeStatus || 0;\ncontext.vCarger1TotEnergy = context.vCarger1TotEnergy || 0;\ncontext.vCarger1SessionStartEnergy = context.vCarger1SessionStartEnergy || 0;\ncontext.vCarger1SessionStartTime = context.vCarger1SessionStartTime || 0;\ncontext.connectedCharger = false;\ncontext.connectedWhng1 = false;\ncontext.connectedWhng2 = false;\n",
        "finalize": "",
        "libs": [],
        "x": 250,
        "y": 140,
        "wires": [
                "856ecdc694e20334"
                "5247249cab547a08"
                "6c45e586532b1de0"
        "id": "914d2a9baac0098d",
        "type": "inject",
        "name": "1s",
        "props": [
                "p": "topic",
                "vt": "str"
                "p": "connected",
                "v": "true",
                "vt": "bool"
                "p": "payload"
        "repeat": "1",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "Inject",
        "payload": "poll",
        "payloadType": "str",
        "x": 110,
        "y": 60,
        "wires": [
                "bc5cc6a7a51164b9"
        "id": "c627e81c7b83067d",
        "type": "debug",
        "name": "debug 5",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload[\"/Ac/PowerFactor\"]",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 760,
        "y": 100,
        "wires": []
        "id": "bc5cc6a7a51164b9",
        "type": "modbus-flex-sequencer",
        "name": "WS-Modbus GW",
        "sequences": [
                "name": "Modbus EM-Whng1",
                "unitid": "2",
                "fc": "FC3",
                "address": "0",
                "quantity": "70"
                "name": "Modbus EM-Whng2",
                "unitid": "1",
                "fc": "FC3",
                "address": "0",
                "quantity": "70"
        "server": "f711060803f2f104",
        "showStatusActivities": false,
        "showErrors": false,
        "showWarnings": true,
        "logIOActivities": false,
        "useIOFile": false,
        "ioFile": "",
        "useIOForPayload": false,
        "emptyMsgOnFail": false,
        "keepMsgProperties": false,
        "delayOnStart": false,
        "startDelayTime": "",
        "x": 270,
        "y": 60,
        "wires": [
                "722014b859612718"
        "id": "5247249cab547a08",
        "name": "EM-Whng1",
        "outputs": 1,
        "energymeter_nrofphases": "3",
        "energymeter_role": "acload",
        "position": 0,
        "switch_1_type": 1,
        "switch_1_min": 0,
        "switch_1_max": "",
        "switch_1_step": 1,
        "fluid_type": 0,
        "ev_vin": "",
        "x": 550,
        "y": 140,
        "wires": [
                "c627e81c7b83067d"
        "id": "6c45e586532b1de0",
        "name": "EM-Whng2",
        "outputs": 1,
        "position": 0,
        "switch_1_type": 1,
        "switch_1_min": 0,
        "switch_1_max": "",
        "switch_1_step": 1,
        "fluid_type": 0,
        "ev_vin": "",
        "x": 550,
        "y": 200,
        "wires": [
                "c627e81c7b83067d"
        "id": "8bdcc27f8e1bdfc4",
        "type": "debug",
        "name": "debug 6",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "x": 540,
        "y": 280,
        "wires": []
        "id": "f475245b3fe836d2",
        "sequences": [
                "unitid": "2",
                "fc": "FC3",
                "address": "20480",
                "quantity": "7"
                "unitid": "1",
                "fc": "FC3",
                "address": "20480",
                "quantity": "7"
        "useIOFile": false,
        "ioFile": "",
        "x": 270,
        "y": 200,
        "wires": [
                "98244d1fcc4fa589"
        "id": "6be3271885881e0a",
        "type": "inject",
        "name": "1x",
        "props": [
                "p": "topic",
                "vt": "str"
                "p": "connected",
                "v": "true",
                "vt": "bool"
                "p": "payload"
        "repeat": "60",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "Inject",
        "payload": "poll",
        "x": 110,
        "y": 200,
        "wires": [
                "f475245b3fe836d2"
        "id": "98244d1fcc4fa589",
        "type": "function",
        "name": "Parse Serial",
        "func": "\n\nif (msg.modbusRequest.name == 'Modbus EM-Whng1') {\n    msg.payload = {\"/Serial\": String(msg.payload.buffer).replace('\\0', '')};\n    return [msg, null];\n}else if (msg.modbusRequest.name == 'Modbus EM-Whng2') {\n    msg.payload = {\"/Serial\": String(msg.payload.buffer).replace('\\0', '')};\n\n    return [null, msg];\n}\nreturn;\n",
        "outputs": 2,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 290,
        "y": 280,
        "wires": [
                "8bdcc27f8e1bdfc4",
                "5247249cab547a08"
                "8bdcc27f8e1bdfc4",
                "6c45e586532b1de0"
        "id": "f711060803f2f104",
        "type": "modbus-client",
        "name": "WS-Gateway 2",
        "clienttype": "tcp",
        "bufferCommands": true,
        "stateLogEnabled": false,
        "queueLogEnabled": true,
        "failureLogEnabled": true,
        "tcpHost": "192.168.13.106",
        "tcpPort": 502,
        "tcpType": "DEFAULT",
        "serialPort": "/dev/ttyUSB",
        "serialType": "RTU-BUFFERD",
        "serialBaudrate": 9600,
        "serialDatabits": 8,
        "serialStopbits": 1,
        "serialParity": "none",
        "serialConnectionDelay": 100,
        "serialAsciiResponseStartDelimiter": "0x3A",
        "unit_id": 2,
        "commandDelay": 1,
        "clientTimeout": 1000,
        "reconnectOnTimeout": true,
        "reconnectTimeout": 2000,
        "parallelUnitIdsAllowed": true,
        "showLogs": true
        "id": "d819801c7cd9cd35",
        "type": "global-config",
        "env": [],
        "modules": {
            "@victronenergy/node-red-contrib-victron": "1.7.8",
            "node-red-contrib-modbus": "5.45.2"
Does any one has an idea what am i missing?
Or is this a bug that other have seen to.
Without code from those functions, hard to say what goes wrong :frowning:
Looks like you might be using Shelly EM - have you tried to simply and install Shelly palette in node-red?
Here the function code.
”Parse Modbus Massage”:
//initialization moved to "Start"
        msgCharger.topic = "Ladestation";
        msgCharger.payload = {"/Ac/Power": ChargingPpower,
                    "/Ac/L1/Power": ChargingPpower,
                    "/Ac/L1/Voltage": ((data[1] * 65536) + data[0])/10,
                    // "/Ac/L1/Current": context.Power/((data[1] * 65536) + data[0])/10,
                    // "/Ac/Energy/Forward": context.vCarger1TotEnergy,
                    // "/Ac/Energy/Reverse": 0,
                    // "/Ac/L1/Energy/Forward": context.vCarger1TotEnergy,
                    // "/Ac/L1/Energy/Reverse": 0,
                    "/Ac/L1/PowerFactor": AcL1PowerFactor,
                    // "/Session/Time": (thisTime - context.vCarger1SessionStartTime)/1000, //<-- Session charging time (seconds)
                    // "/Session/Energy": ((data[65] * 65536) + data[64])/10 - context.vCarger1SessionStartEnergy, //<-- Session charging energy (kWh)
                    // "/Session/Cost": (((data[65] * 65536) + data[64])/10 - context.vCarger1SessionStartEnergy) * 0.4, //<-- Session cost (no currency)"
                    "/DeviceType": 71,
                    "/Position": 1, //       <-- 0=AC Output, 1=AC Input
                    // "/PositionIsAdjustable": 1,
                    "/IsGenericEnergyMeter": 1,
                    "/ErrorCode": 0};
    msg.payload = {"/Ac/Power": ((data[41] * 65536) + data[40])/10 - ChargingPpower,
                "/Ac/L1/Power": ((data[19] * 65536) + data[18])/10 - ChargingPpower,
                "/Ac/L2/Power": ((data[21] * 65536) + data[20])/10,
                "/Ac/L3/Power": ((data[23] * 65536) + data[22])/10,
                "/Ac/L2/Voltage": ((data[3] * 65536) + data[2])/10,
                "/Ac/L3/Voltage": ((data[5] * 65536) + data[4])/10,
                "/Ac/L1/Current": ((data[13] * 65536) + data[12])/1000,
                "/Ac/L2/Current": ((data[15] * 65536) + data[14])/1000,
                "/Ac/L3/Current": ((data[17] * 65536) + data[16])/1000,
                "/Ac/Energy/Forward": ((data[53] * 65536) + data[52])/10,
                // "/Ac/Energy/Reverse": ((data[79] * 65536) + data[78])/10,
                "/Ac/L1/Energy/Forward": ((data[65] * 65536) + data[64])/10,
                "/Ac/L2/Energy/Forward": ((data[67] * 65536) + data[66])/10,
                "/Ac/L3/Energy/Forward": ((data[69] * 65536) + data[68])/10,
                "/Ac/L2/PowerFactor": AcL3PowerFactor,
                "/Ac/L3/PowerFactor": AcL3PowerFactor,
                "/Ac/PowerFactor": AcPowerFactor,
                // "/Ac/Frequency": AcFrequency,
                "/DeviceType": 71,
                // "/ProductName":,
                // "/CustomName":,
                // "/Mgmt/Connection":,
                // "/Mgmt/ProcessName":,
                // "/Mgmt/ProcessVersion":,
                "/Connected": true,
                // "/DeviceInstance":,
                // "/ProductId":,
                // "/Serial":,
                // "/HardwareVersion":,
                // "/FirmwareVersion":,
                "/ErrorCode": 0};
        msg.topic = "EM Whng1";
        msg.topic = "EM Whng2";
return;
“Parse Serial”:
    msg.payload = {"/Serial": String(msg.payload.buffer).replace('\0', '')};
    return [msg, null];
    return [null, msg];
return;
You can have also a look in the Flow I attached before.
Hello, is AcL3 power register right? first you use 32 and then 23
Thanks, that’s an typo!
But has no effect on the Energy.
These zeros/spikes only accrue when Node-Red reloads or deploy. If all is running normally the virtual device is running fine. It seems for me that there is a handling issue on DBus or VRM that turns a “unavailable”/”null” into 0.
Try to declare this in let/var.
What debug show in first send to vrm?
I’ve found the issue! @Victron
It’s because I’m sending the “connected” message along with the “payload” objects.
msg.payload = {"/Ac/Power": Bytes2Int32(data[40],data[41])/10,
               "/Ac/L1/Power": Bytes2Int32(data[18],data[19])/10,
               "/Ac/L2/Power": Bytes2Int32(data[20],data[21])/10,
If I make sure that the payload objects overwrite the default values first and then send the “connected” message, no zeros appear.
If payload objects sent together with the “connected” message, only the energy meter is connected (with default values) without the payload objects being applied.
I assume that if I set the “Initialize with defaults” box, to “No”, I can handle this scenario—ensuring that only valid values are written and no unchecked zero values are written.
My solution is to delay the “connected” message slightly, so that valid values have already been sent to the device.
Edit: See also this topic Virtual EM with type EV charger reports total kWh in VRM upon Venus upgrade
