Result is a visible EVCS widget on the homescreen, but when I look in devices on the console I see only actual power, and the total. Is this expected behaviour?
The position is showed on the widget screen as on AC-out. I switched it to AC-in with the correct path, but nothing changes in the widget.
I did a charge last night and is see the darn power in the widget graph, in all the rest it is not shown as EV charger use. Expected behavior? (edit, last night’s charge is visible in betavrm)
But only the actual power en total energy are recoded into the virtual energy meter with role EV charger. Am I doing something wrong? Or is this intentional/unfinished?
And while charging I also see for the virtual EV node that charge status is ignored, gives unknown in the device list on the console, but ‘2‘ is sent to it, so I expected ‘Charging‘
Yes it was in my first post, but I see you already found it
Now we hope this data is going to do something with D-ESS. I hope very soon D-ESS knows how many kWh is needed for a charge, and at least plans this as expected use at the best moment, based on historical data. Then I can match my charger with the D-ESS planning. Fully automated will be better, but first things first..
The requirement to manually update the timestamp has been removed in 1.7.9 of node-red-contrib-victron. That should land in the next beta release of Venus.
