The VRM advanced tab displays the widgets. With the latest revision of VRM, one can no longer arrange the layout the default widgets. Only the custom widgets can be moved.
Hi @selwyn,
The most likely explanation is that the widget lock has been activated;
It’s also possible that you’re no longer the admin of the site.
Thank you Guy. It was strange that the custom widgets could still be moved.
