VRM loses EVCS after 24hrs
After about a day the remote control on the VRM dashboard loses the EVCS module the inverter module is present
Information on the EVCS is displayed on the dashboard but shows only what was happening at the time it dropped out
If the Cerbo GX is rebooted via the option on the remote console everything comes back and all functions are normal
Both the firmware on the Cerbo and EVCS are up to date
Any ideas
Hello Spencer. Did you see the ‘W104-GX communication warning’ message on the EVCS dashboard(EVCS web interface) when it happened?
Thank you for your reply
I can not see any errors on my dashboard or remote console I am away from EVCS so can’t check with victron connect is there another way to check for errors
