In GUI-V2 I noticed that under VRM device instances there are two instances running on the same number. It’s called unconnected pvinverter. But all my pv inverters are connected. Is that normal or does it cause problems?
I don’t have nonexistent devices in the device list on VRM Webportal. Everything is fine for me in the VRM Webportal device list. Only in the VRM device instances in Venus OS.
Not on the Device list on VRM portal.
Look on widget creation area of the VRM portal.
Meaning select Advanced, then on the upper right corner, Widgets.
