VRM Dashboard: Tank Temperature Not Displayed for Virtual Tank Device
I am using a Shelly Temperature & Humidity sensor integrated through Node-RED.
I created a Virtual Device in Node-RED and enabled the “Include Humidity” option. As expected, the VRM Dashboard shows a card displaying both temperature and humidity values.
I tried to do something similar for a water tank, using a Virtual Tank Device that provides both tank level and water temperature measurements.
The tank card on the VRM Dashboard only shows the tank level. However, when I open the device details, I can see that the temperature value is present and being received correctly by the system.
My question is:
Is there a limitation for Virtual Tank Devices that prevents temperature from being displayed on the VRM Dashboard, even when “Include Temperature” is enabled?
I have not tested this functionality on earlier Venus OS versions, so I cannot confirm whether this behavior is new to Venus OS v3.80-33 or if it has always worked this way.
