Hi all,
I’m using the new Virtual Indicator node in Node-RED on a Venus OS Large test system and I’m running
into a limitation in VRM. I’m posting it here to check whether this is expected, planned, or whether I’m
missing a setting.
Environment
- Venus OS Large 3.81
- node-red-contrib-victron: [version from palette manager]
- VRM portal (production)
What I did
I created four Virtual Indicator nodes (two Discrete, two Value type) in the same Group, “Calitatea aerului”
(air quality), fed from a flow with msg.payload = { Value: n, Status: 0 }.
What works
The indicators show up correctly in the GX Switch pane (GUI v2) and in the VRM Switches panel (screenshot 2).
The problem
In VRM > Device list they appear as four separate “Expansion IO” devices (instances 100, 103, 104, 105;
screenshot 1). Expanding a device (+) only offers “Delete”. In Advanced > Widgets, when I try to create a
widget for them, VRM offers the predefined attributes of a GX IO-extender (PWM etc.), not the indicator
values. So the values published under /GenericInput/0/Value can’t be graphed in VRM.
What I found in the source
In v1.7.29 the node registers the service as com.victronenergy.switch.vindic_ with ProductId 0xC069,
which I assume is why VRM treats it as an I/O extender.
Request / questions
- Is it planned to log the indicator’s /GenericInput/*/Value (and Status) to VRM, so they can be used as
widgets and graphs? Or to give the indicator its own device type with matching attributes? - If not, is there a supported way to get history of custom values into VRM?
For now I’m using a local Node-RED dashboard for history, but having these in VRM next to my other devices
would be much better.
Thanks!
