VRM API - Solar Yield Forecast, how to read response?
I’m new to Node RED and still learning, currently experimenting. I’m using the VRM API in NodeRED to obtain the Solar Forecast from the VRM system. I’m getting the following response:
How should I read the response data? Any suggestions. Is the total expected solar generation 18K4 kW? What is the 17479512… number?
In VRM GUI I’ve the following:
18,4 kWh is the expected total day production (it’s between VRM’s 17 .. 21 kWh)
17479512… is the time in unix time format (unix timestamp)
