Major change on VRM API
Dear @Barbara,
2 days ago the VRM API was obviously changed. It shows now amost the tripple value for solar forecast.
In the late afternoon og August, 5th the value doubled, on August 6th it got trippled.
My configuration on VRM API
Result is that
It worked nearly a year correctly. My plant can generate 75kWh per day max. Therefore the result of 202kWh does not make any sense. In VRM Portal 55 to 68kWh are indicated currently.
Any idea, why it does not work anymore? Any major change from your side?
Its been discussed in this post VRM Forecast data doubled(?) - #25 by jarco
It seems that they are working on fixing things …
Lates afternoon issue got obviously fixed!
Thanks a lot for the immediate interaction!
