VRM Advanced Graphs - Reference Line
Hi. I actively use VRM to monitor my van systems. I have a graph for my Orion XS that shows input voltage and it’s a useful proxy (when not under load) for my starter battery SoC. I’d really like to be able to add a fixed value line on that y-axis for a 50% SoC at-a-glance warning. I have a VRM alarm set but a visual refence line would be very helpful. Is there a way now or, if not, would there be a way for Victron to enable such a feature?
As you are using VRM then presumably you have a GX device like a Cerbo. Enable Node Red, create a virtual battery, inject your required value for your 50% reference voltage to the virtual battery, add your virtual battery voltage and the Orion input voltage to a custom widget in VRM l and voila, you will always have a reference line at your desired voltage along with the Orion input voltage.
I do have a Cerbo GX v2. I’ve not had to get involved with Node Red so far. Is it managable from the VRM remote console?
I see in Integrations that I need to enable the Venus OS Large Firmware to make Node-RED available but have so far not found how
Settings > General > Firmware > Image Type and select large. You will then be prompted to download the large image which included Node-RED.
I selected Large and nothing happened so I’m trying a run firmware update
Thanks so much for this BTW
I’ve never used Node-RED. Claude tells me I need to know these things:
  1. The correct MQTT topic path on the Cerbo for a virtual device value
  2. The right interval for publishing (probably every 30 seconds to match VRM logging)
  3. How VRM exposes it as a graphable data source
Now 1 & 2 are unknown to me. £ I suspect will simply be a selectable device.
Large firmware installed, Node-RED enabled but I can’t access Node-RED on remote console. From VRM I can now reach Node-RED but how do I register a login? My VRM login doesn’t work
I thi nk I have it now. Virtual battery shows in device list at correct volts etc so now I’m just waiting for VRM to log it.
It sounds like you are getting there, I have virtual batteries set up and added to custom widgets, the data should come through automatically.
I had selected starter battery voltage as parameter but needed voltage. It’s now set and graphing well. Thanks ever so much, this was excellent advice.
