Virtual Heatpump Node-RED
Hi everyone,
Yesterday I noticed in the VRM beta that consumption is now split into categories such as EV charging and Heat pump. I also saw that the Energy Meter VM-3P75CT has this role available in the settings.
I’m not sure whether this will eventually be used for the DESS strategy, although that would be pretty cool.
Now I was wondering whether I can also assign this role to a Virtual Device or Virtual AC Load. My heat pump is fully monitored via Shelly, but through a Z-wave variant connected to Home Assistant.
My idea was to link the data via a Virtual Device or Virtual AC Load, but I don’t see any option for the ‘Heat pump’ role.
Does anyone know whether this is already possible?
Not currently no. There are some changes planned for 3.80 that might introduce this but no promises.
It has been requested, myself included.
Thanks, Nick, for the quick response!
Is it already known whether the system, such as DESS, responds to this in the case of an Energy Meter VM-3P75CT with the role set to “Heatpump”? Or is it, for now, only a display of the different consumption values?
I believe this is more visualisation currently.
I don’t have insight to what the plans are for this but it certainly does allow for more fine grained control of loads. Will be interested to see where it goes.
What I have found is that there is little that we can come up with as a community that hasn’t already been dreamt up by the engineering team. :slight_smile:
If you’re lucky maybe @Barbara has some insights that can be shared on the next release notes post.
Hi @Boekel1 ,
For now, the split consumption is indeed only to get more insights in the main consumers of your installation.
In the near future, DESS controls EVCS usage on the ideal times from a cost point of view. We are running tests on Heatpump controls as well. As it currently stands, DESS will probably be able to run the salmonellaLegionella program at the ideal time of day at least.
Correction : Legionella program :wink:
Heatpump can now be used in 3.80 with a virtrual device node.
Don’t forget to turn of initialize with default values otherwise you will get a huge spike in consumption data.
