I’m using Nodered on v3.73 on a Cebro GX and would like to access (and update) the usage forecast.
This can be done in the UI and should also be possible via VRM-api v 0.4.3.
If I look at the packages installed, it shows that victron-vrm-api 0.3.11 is iknstalled.
If I look at the install tab for victron-vrm-api, it shows victron-vrm-api 0.4.3 but also marked as installed.
How do I make 0.4.3 active?
Or is this only going to be active with a later release of VenusOS (e.g. 3.80 or later)?
Thanks, Willem-Jan
