Levert de Smart inverter 24 | 1600 constant 230 Vac of wordt die 230 Vac lager als de accu spanning lager wordt ?
En als dat zo ia, hoe kan ik dat oplossen ?
The output voltage of Victron inverters is stabilized, independent from battery voltage (if it is within operational range, 18.6 - 34 V for Your inverter).
This is from Your inverters manual:
“AC Output = 230Vac ±2%, 50Hz or 60Hz ± 0,1% (Non-linear load, crest factor 3:1) “.
I have smaller one (24/800), it performs fine at battery voltage from about 22 till 28 V (haven’t lower or higher battery voltage) and loads from 0 till short overloads till 1700 VA.
Thank you
