I would be grateful for advise as to whether this unit has a Starter Battery Charging capability as I’ve been unable to locate any information relating to my question.
The unit was fitted to a narrowboat built in 2009.
Hi Brian. According to the manual the phoenix does have a trickle charger for the start battery.
Have a look near the relay / temp / volt sense terminal blocks. It will be a male spade terminal marked as TRICKLE CHARGE (?).
It will look something like this photo. Between and below the battery connection.
Thank you for your prompt response.
Unfortunately the image you sent differs from my unit in.
The bottom of the two PCBs is totally different and is labelled as PCB000010032.
However, the top PCB010021-4 has a blue block connector with 6 possible connection; 2 have the positive and negative Battery Temperature wires.
Unfortunately I can’t find options to attach photos to this email.
I realise the output only provides a trickle charge and without wishing to be more of a pain, so that I can select the correct cable and fuse, would you be able to provide detail regarding maximum current?
