Connecting Phoenix 12/250 to MPPT 75/15
Hello, I have a working setup with the MPPT connected to a solar panel and 100Ah battery that I am very pleased with. I recently bought a Phoenix 12/250 that I want to integrate.
Can I connect the Phoenix to the “Load” of the MPPT or do I need to go to the battery directly?
Thanks.
Battery direct, inverters have a high inrush current at start up that overloads the load output. As ever, the manual covers this and shows a work around in Section 3.8.1, you use the 12V output from the load output to switch the inverter on/off.
Thank you so much for this insight!
However, my manual doesn’t have a section 8.3.1 nor does it seem to cover this subject?
Always best to go onto the Victron product page and download the latest version.
