quick question, hopefully not asked before too often… ![]()
Friend of mine had a Van custom built by a company here in Germany. For some reason, they only installed 230V via outside shore power, but not via 12v-230v inverter.
I am now wanting to install the Phoenix Inverter 12V 250W.
Question that i have:
Can i connect the inverters AC out simply to the existing AC circuit of the Van. My worry is that when the Van is connected to shore power, there is “incoming” AC power on the Inverter’s AC out, and i wonder whether this causes damage to the inverter.
Alternative is that i run a 2nd AC outlet circuit, which is NOT connected to the 230V from shore power, and ONLY gets AC power via the inverter.
Sorry if this was a dumb question, i looked and could not find the answer. Even the circuit drawings on victron did not specify this question to me.
Thanks in advance and happy Victroning!
Kai
