Victron Phoenix 12/3000 trips LiFePO4 BMS on connection – need advice
Hello everyone,
I’m running into the following issue and hope someone can help me.
I have a Victron Phoenix Inverter 12/3000 connected to a 12V 300Ah LiFePO4 battery.
When I connect the inverter, it seems to draw a large inrush current (likely due to charging the internal capacitors), which causes the battery’s BMS protection to shut down immediately.
Result:
  • The battery cuts off right away
  • The inverter does not start
My question:
:backhand_index_pointing_right: How can I solve or prevent this?
I was thinking about:
  • using a pre-charge resistor
  • or another way to limit the inrush current
But I would really appreciate advice on the best and safest solution in practice.
Thanks in advance!
Best regards,
Robert
You need a prechatger circuit, see
Or use the search function on here for precharge to see DIY options using resistors or light bulbs.
