Hi all,
I’m running a three-phase off-grid setup with three Multiplus-II 48/6k5/100 inverter/chargers (one per phase). I’d like to understand the correct breaker sizing for the household distribution groups on the output side of the inverters.
Specifically: when a short circuit occurs in one of the household groups, what is the minimum breaker rating (and type) required to actually trip before the Multiplus-II units are damaged or shut down in an uncontrolled way?
Some context:
• In off-grid mode there is no grid to contribute fault current — the three Multiplus-II 48/6k5/100 units are the sole source of energy
• The Multiplus-II 48/6k5/100 has a specified peak current and short-circuit current output, but I’m unsure whether this is sufficient to trip standard MCBs in the instantaneous range
• I want the breaker in the affected group to trip first, protecting both the wiring and the inverters
Questions I’m hoping the community can help with:
- What short-circuit current does a Multiplus-II 48/6k5/100 actually deliver into a fault in off-grid mode?
- Is this enough to trip a type-B, type-C, or type-D MCB instantaneously, or will the Multiplus-II go into overload/shutdown before the breaker trips?
- What breaker type and rating is recommended for output group protection in this setup?
- Are fuses a better choice than MCBs on the output side for off-grid systems like this?
- Are there any Victron settings that influence short-circuit or overload behaviour in a three-phase off-grid configuration?
Any experience, calculations, or documentation references are very welcome. Thanks!
