Hello i will be storing my sailboat for 10 months and i have 4 Smart Lithium 200A, according to the documentation :
When leaving the system unattended for some time, make sure to either keep the batteries charged during that time or make sure the batteries are (almost) full and then disconnect the DC system from the battery.
And Victron also says: Low self-discharge rate The self-discharge rate has been significantly improved and is now a maximum of 2 % of the battery capacity per month .
So i understand i should store the Lithium at 100 %. Temperature is 30C year long. The batteries will be fully disconnected and they will discharge approximately 2 % per month so after 10 months they will stand at about 80 %.
Does anyone has a different experience or opinion ?
Did you go ahead with ~100% and a full disconnect? How did the batteries look after the 10 months? I’d love to know the voltage or SoC you came back to, and whether you saw any cell imbalance.
I’m in a similar spot: 3 × Smart LiFePO4 12.8V/330Ah with a Lynx Smart BMS 500, boat on the hard in New Zealand for about 13 months, so a bit past the 1-year storage spec. My plan is to fully charge, switch the Lynx OFF, disconnect the battery positives, and have someone read the battery voltages over Bluetooth once a month.
Your experience would help a lot. If anyone else has stored Smart batteries disconnected for a year or more, I’d be glad to hear how it went too.
Thanks, that’s useful. Victron’s datasheet for the Smart batteries gives max 1 year storage fully charged, so I’ll go in near 100%. A 6-month top-up would mean some else would be reconnecting/ charging/ disconnecting the battery positives. I don’t go down this path…Guess I’ll have the voltages read over Bluetooth monthly and only top up if they start dropping. Has anyone tracked how fast Smart batteries actually lose voltage when fully disconnected?
I don’t for the victron ones. But I do know other 12v ones. And it was roughly what was worked out by north captain.
I did have a friend who left 2 x 12v for over a year and they went into a deep sleep. One BMS woke up one did not but the cells weren’t low enough to have damaged. (BMS was replaced)
Again I’m not speaking for Victron here. Just experiences.
What I do is have a victron wall charger on with the rebulk offset adjusted so that it basically only charges once every few months with a top up. So far so good with it anyway.
