Victron IP65 cycles continuously between Bulk and Absorb
I had high hopes for the Victron IP65 charger I ordered, so I can charge a LiFePO4 battery when I am at an RV park and there is no sun.
Received it today, it is defective. It cycles continuously between Bulk and Absorb, and the battery is not charging.
I arranged a return, since a Google search reveals it is a known hardware issue.
Not sure if I’ll buy an IP22, those don’t seem to have issues, but it’s a lot bigger and space is tight.
IP65 and IP22 only describes the ingress protection level of the Victron components.
what exact charger did you use and what settings?
