Charging issue IP67
Im trying to charge a 24 volt LiPO4 battery the battery is flat but the charger starts on bulk then after 5 seconds or so clicks over to absorption and 15 - 20 volts but no Amps going into the battery
Any suggestions would be welcome
Hi I had a similar issue with my 12V see outcome here BSC IP65 12 25 no bulk charge - #2 by omasback
Without more details about your system I would guess that there is a blown fuse or loose connection somewhere between the charger and the battery.
