I was wondering if I had to use the Bluetooth connection to set up the charger before I started using it.
Also, is it normal that the voltage gets so high? My understanding was the voltage should get up to about 13.4V when the engine is running. So I was surprised when the voltage read 15.5V right after I took off the Victron charger. What should the voltage be after using a charger on a typical lead-acid battery?
Always consult your battery manufacturers owner’s manual for the correct charge profile. Some niche FLA batteries have slightly different charge profiles than a typical off-the-shelf battery like an Interstate Deep Cycle RV battery.
