Victron IP22 -> LiFePO4 with 14,8V?
Hi all, I plan to charge an Acurate Impulse I105L3, which has an end voltage of 14,8V. Is the VIctron IP22 able to handle that voltage? The datasheet says “Li-on” 14,2V but floating voltages shall be able to get configured. Can I configure 14,8V for charging my battery? Thanks a lot, Lothar.
I believe so. Download the VictronConnect app to your phone, this will be needed to program the charger when you get it. Open the app, click on the 3 lines menu icon and select demo library, choose the charger you are looking at and try and program it to see what you can do. You will need to use a “user profile” rather than a preset.
