Victron connect android and multi settings
Hi. I am trying to change some settings on my multi 5000/70 ii gx via Victron connect. When I tap the multi in the device list I don’t see an overview. If I tap the settings cog I only see network settings. Not sure if the internal gx is the problem. The system has recently been removed started and I am sure this has always been the same behaviour. All the other devices work as expected
The Inverters do not have Bluetooth, to configure them you would use your PC using the Interface MK3-USB - Victron Energy, or VRM if you had a Cerbo connected to internet.
If using your pc with VE.bus you would use the VE.Bus system config software.
If you have the Cerbo, you could then use the portal to pull the config file from the Multiplus in the device list. You would then configure this file via the VE.Bus sys config software and reload it via the VRM
These are the only two ways I know to config the inverters/chargers
Correct see the manual.
VictronConnect connects to the inverters via a USB-MK3 accessory cable, or via the VE.Bus Smart Dongle (both sold separately).
