Hi, for an RV application, I would like to charge a vehicle lead acid 12V chassis battery using three 12 V AGM house batteries, while vehicle engine is off. I purchased an Orion-TR 12-12V 9A Isolated DC-DC Converter, however the product packaging states “not intended for battery charging.”
I looked at Orion XS products, but these use the chassis battery (connected to an alternator) to charge an auxiliary (house) battery.
Not necessarily, you can use an Orion XS to charge the starter battery. Just a matter of charge parameters.
To properly charge a battery you should use an Orion Smart (including the Orion XS), since these have proper charge algorithms.
If its just to keep a maintenance charge on the starter battery you could also use a non-Smart Orion, however a prolonged, high charge voltage can reduce battery lifetime. So take care when setting the Trimpotentiometer. And a good voltmeter should be used to check the setting
OGPS
(Ed @ Off-Grid Power Systems - offgridps.com)
3
It’s not ideal but if you’re just looking to keep the chassis battery topped up vs charging from a deep discharge then you can use the converter. Set the output voltage to a float voltage. The alternator or primary charger can do the heavy lifting.
We sometimes use these small DC-DC converters as a maintenance charger on motorhomes that spend a lot of time parked off-grid. The solar chargers on the house bank side effectively act to float charge the chassis battery to ensure they can start the engine. However, I would recommend you check to see if your dealer will allow you to return the DC-DC converter and exchange it for a charger. That would be the better route.
