I’m running the latest VenusOS firmware version on a Rpi with GuiMods installed. Maybe a feature request, but I’m wondering if it’s possible to rename the label of “PV Inverter” on the main screen. In my case, I am using a VE AC Current Sensor on aux input 1 of a VE.BUS connected Multiplus. On VenusOS, this automatically shows up as “PV Inverter” and I don’t see anyway I can relabel it. For my installation, it is not “PV” but rather shorepower or genset AC in and it would be nice to have it labeled as such.
You would need to edit the QML code that generates the page.
Since you are using GuiMods and appear to be using the GuiMods Simple overview that would be: /opt/victronenergy/gui/qml/OverviewHubEnhanced.qml
Thanks! That worked. Would be awesome if there could be an option right in the settings to rename. Thank you for the workaround! It was something that always bugged me.
