Venus-signalk MQTT connection
Title:
MQTT on LAN (Cerbo GX v3.72) – connection refused / inconsistent interfaces / SignalK integration
Description:
I’m trying to set up a local (LAN) MQTT connection between a Cerbo GX and a SignalK server (Raspberry Pi), as a more robust alternative to the existing VRM integration.
Current setup:
  • Device: Victron Cerbo GX MK2
  • Firmware: v3.72
  • MQTT access: enabled (Settings → Services → MQTT Access ON)
  • Local network security profile: tested (currently verifying Secured vs Unsecured)
  • Multiple IP addresses on Cerbo:
    • 192.168.1.101
    • 192.168.1.102
    • 192.168.1.105
Goal:
  • Direct local MQTT (LAN) integration with SignalK
  • Using signalk-venus-plugin in MQTT mode (instead of VRM)
Problem:
  • MQTT connection on port 1883 results in:
    ECONNREFUSED
  • Tested from Raspberry Pi with:
    mosquitto_sub -h 192.168.1.102 -t "N/#" -v
    mosquitto_sub -h 192.168.1.101 -t "N/#" -v
    mosquitto_sub -h 192.168.1.105 -t "N/#" -v
Results:
  • Some IPs → connection refused
  • Some IPs → connection established but no data received
  • Additionally, the signalk-venus-plugin keeps reverting to:
    tcp:host=...,port=78
    (D-Bus over TCP), even when MQTT is explicitly configured
What I already tried:
  • Enabled/disabled MQTT access
  • Rebooted Cerbo GX
  • Cleared all plugin settings (no VRM, no D-Bus)
  • Adjusted local network security profile
  • Tested all available Cerbo IP addresses
  • Verified network connectivity (ping/SSH OK)
Questions:
  1. On which interface/IP does the Cerbo GX MQTT broker actually listen?
  2. Is port 1883 still available in Venus OS v3.72, or only TLS (8883)?
  3. Is a specific “Local network security profile” required for plaintext MQTT?
  4. Is it expected behavior that MQTT connections are accepted but no data is published?
  5. Can the presence of D-Bus TCP (port 78) cause clients/plugins to fall back automatically?
  6. What is the recommended way to reliably use local MQTT (LAN) instead of VRM?
Additional context:
  • VRM integration via signalk-venus-plugin works perfectly
  • Goal is redundancy: local MQTT + VRM fallback
  • Network is stable and functioning correctly
Any insights would be highly appreciated, especially regarding MQTT behavior in recent Venus OS versions.
Thanks!
